Valve adjustment on 2006 4cyl Accord
Old Apr 17, 2006 | 12:26 PM
RTexasF's Avatar
Super Member
Default RE: Valve adjustment on 2006 4cyl Accord
ORIGINAL: deserthonda
ORIGINAL: RTexasF
HaHa! No I wasn't. Are you a Honda Master Tech?
Ok a little history about my background.........
started working on Hondas in 1980.... worked in dealership in Wisconsin for 8 years. moved to AZ worked at dealership for 8 years ,,Opened up my own shop 10 years ago, still going strong,, we specialize on Hondas and acuras
Qualifications ...
26 years experience
ASE master tech,
Honda master tech
Honda Top Tech..
[sm=groupwave.gif] YOU are the man!!
Old Apr 18, 2006 | 03:00 PM
7thGen's Avatar
The master tech at the shop I work at asked about this when he went to Honda school and was told that the 03+ I4 Accords only get it if they are noisy. He was told that the K series has roller rockers and rarely need adjustment. I have 67k on my 03 I4 and they still are not making any noise. One catch is that the injectors on the 03+ are very noisy so make sure you don't confuse the noise as the valves.
Old Apr 18, 2006 | 06:02 PM
sir_nasty's Avatar
what about my 94 EX SOHC Vtec, does the 30k rule apply? Is this something I could do myself? Never tried it on a honda before but I've done it on Pinto's/Mustang II's... Pretty much the same?
Old Apr 18, 2006 | 06:24 PM
deserthonda's Avatar
http://www.ozaccord.com/forums/showthread.php?t=27
yes do at 30k..
Old Apr 18, 2006 | 07:21 PM
lightshow's Avatar
desert do you have an alignment machine?
Old Apr 18, 2006 | 08:04 PM
sir_nasty's Avatar
what is the valve lash supposed to be at for a 94 accord ex? is intake ..10 mm exh .012 mm correct? and just to make sure I understand for my vehicle, at TDC I'm on #1, Counterclockwise 90 is #3, 90 more to #4, then 90 more to #2? is that correct?
go-nogo gauges... and I thought those were only for a .50 Cal headspace and timing adjustment in the military... *L*
Old Apr 18, 2006 | 08:29 PM
  #17
ORIGINAL: lightshow
yes we do.........SNAP -ON
Old Apr 18, 2006 | 08:32 PM
  #18
ORIGINAL: sir_nasty
YOU GOT IT......if you read the direction and follow them, it is a piece of cake... make sure engine is cold before adjusting valves,,
Rice
Jun 26, 2012 06:01 PM
eleiko
Jun 15, 2011 10:46 PM
deserthonda
Dec 31, 2007 09:16 AM
weekendwrench
Jan 2, 2007 11:56 PM
sfox555
Feb 2, 2006 07:42 PM
