Valve clearances 2003 2.0 VTEC 4 cyl
Old Aug 18, 2015 | 06:57 AM
kwakers's Avatar
Default Valve clearances 2003 2.0 VTEC 4 cyl
I am about to do the valve clearances I just need to know what gap feeler gauge I need for inlet and exhaust cheers in advance
Old Aug 18, 2015 | 11:58 AM
travrach's Avatar
Valve Clearance for 2003 2.0 DOHC V-TEC
Intake 0.21 - 0.25 mm (0.008 - 0.010 inch) Exhaust 0.28 - 0.32 mm (0.011 - 0.013 inch)
Adjust the valves only when the cylinder head temperature is less than 100°F (38°C)
Note this spec should be on the under hood decal also.
Old Aug 21, 2015 | 08:01 AM
Turtlehead's Avatar
Also, if you have the original hood on the car just look at the sticker on the underside of the hood and it will confirm the clearances.
jfidelh
Feb 26, 2013 10:03 AM
JimTrail
Aug 26, 2012 08:13 PM
Honda Accord Tuner
Feb 2, 2010 08:41 AM
gaugeman
Mar 8, 2008 08:34 AM
mrmatrix
Aug 12, 2006 05:39 PM
