valve cover gasket job 97 Accord
Old Jan 20, 2012 | 04:11 AM
zReizZLeS909's Avatar
Exclamation valve cover gasket job 97 Accord
Ok, so im pretyy good with the f22b2 engine so I decided to buy a vcg kit and replace all seals/gasket (due to leak) my question is, the "rocker-arm assembly" if oil gets inside the fastner screw hole does that need to be taken out? I dont know if oil being inside the bolt holes messes with the torque specs Because ive already broken one fastner/bolt. these are the torque specs im going by (8mm = 16ft-lbs) (6mm = 12ft-lbs)
Old Jan 20, 2012 | 06:29 PM
For the bolts that hold the cover.....I'd be in the 7 to 8 ft lbs range...just me
Attached Thumbnails valve cover gasket job 97 Accord-5th-gen-valve-cover.jpg
Old Jan 21, 2012 | 04:22 AM
I did 10.ft-lbs because my torque wrench doesnt go any lower >.< and I put it all back together, now lets see if it leaks
Old Jan 21, 2012 | 08:12 AM
Again, want to be sure we are talking about the same bolts.......Holding the cover on is one. First pic I posted
The "rocker shafts" to the head are something else.
Old Jan 22, 2012 | 01:13 PM
Well I torqued the rocker shaft bolts to 16lb and the smaller "12" to 10lbs and it hasnt exploded on me yet but I do still have a small leak in cylinder(4) I think I should apply hondabond underneath the grommets
zedjr
Jan 31, 2013 04:49 PM
B501
May 27, 2012 08:28 PM
JimTrail
May 21, 2012 09:12 PM
noiseordinance
Dec 12, 2011 07:53 PM
thunder_x
Jul 9, 2007 11:57 AM
