Vehicle Speed Sensor not working
Old Sep 4, 2010 | 02:16 AM
spartadrive_in's Avatar
Default Vehicle Speed Sensor not working
Hello, I have a Haynes Repair manual and was able check the OBD and got a '17' for 'VSS malfunction'.
Doing what the repair manual told me I disconnected the harness and with my ohmmeter checked ground continuity and it checked out. I did not get battery voltage on the BLK/YLW pin like the book told me I should have, instead I got 0V. I come to find that there is continuity between that pin and ground. Should this be normal or am I right to assume there is a short in the harness somewhere??
Also I checked all my fuses even though I did not find one that was labeled for such.
Any suggestions? How could I find a short if that is indeed the case?
Old Sep 4, 2010 | 05:57 PM
Did you do the test with the key turned to the II (normal running) position? The engine doesn't have to be running.
There are 3 wires that go to the VSS. One should have continuity to ground, 12V and ~5V.
PeteGibson
Jun 27, 2014 02:34 PM
sfcool
Nov 2, 2007 10:42 AM
Sliom001
Sep 24, 2007 09:56 AM
ukbuckstop
May 2, 2007 08:56 PM
PJ_STYLES_95AccordEx
Aug 9, 2006 09:51 PM
