Vibration at 2000-2200 RPM
Old Dec 3, 2006 | 11:35 PM
ourhonda
Default Vibration at 2000-2200 RPM
I just bought a '97 SE 4cyl. auto and am trying to work a couple of bugs out of it. It has 145K on it. There is an annoying vibration around 2K that happens driving the car or just sitting there. I had the exhaust shop check it out and anything they did didn't cure it. They suggested the motor mounts. Is this possible? Can I check them and replace if needed? Thanks.
Old Dec 4, 2006 | 02:22 AM
deserthonda's Avatar
Default RE: Vibration at 2000-2200 RPM
Input the year and model in your sig so members will not have to ask,, i noticed you got another post open asking about a lug nut repair
As for the vibration .if the motor mount (s ) are bad you would notice it mostly at idle especially since it is AT tranny .. but to chk them take a visual look at the frt one. the rear it is easier to put a floor jack under the engine or tranny and raise it up a bit, look at the mount ,,if it is split open or badly cracked , it needs replacing ,,,,,,,,,
warria98
Apr 4, 2012 03:48 PM
IWL BCNU
Aug 5, 2009 02:24 PM
superballz00
Oct 6, 2007 08:36 PM
nixalot
Mar 22, 2007 12:03 PM
rottevnm
Aug 17, 2006 09:59 PM
