Vibration at 2500 RPM in 5th gear - 04 Accord
Old Apr 3, 2009 | 10:03 PM
BigShelby's Avatar
Default Vibration at 2500 RPM - 04 Accord 5 speed
I've been trying to figure out the source of a vibration. 04 4 cyl., 5 spd Accord, 110,00 miles. The vibration isn't serious but noticeable, more annoying than anything. Typically the car will exhibit a slight vibration at 2300-2600 RPM usually under light accleration in all gears. Under full throttle it's not felt.
Is there a TSB for this? I think it's an engine mount. Let's rule out tire/wheel vibrations. I had the 105k performed and the mechanic said the engine was in great shape. I read about the engine mount vibe at idle on automatics.
Anyone else have this issue?
Thanks...
Old Apr 6, 2009 | 08:37 AM
Swap your tires around to rule out tire/wheel balance issues.
If it's only under load, it could be the drive axles.
Old Apr 7, 2009 | 05:26 PM
draser's Avatar
I'm not sure what the correct speed ranges are for each gear, but assuming they're ok I'd check the clutch as well.
RedKnight
Jan 22, 2013 01:15 PM
blly8325
Mar 23, 2012 06:10 PM
kraftwerk
Aug 22, 2011 11:04 AM
mpmoe2002
Nov 21, 2010 12:22 AM
tjk
Sep 30, 2010 01:26 PM
