Vss
Old Jun 6, 2011 | 06:30 PM
scott134713's Avatar
Default Vss
I apoligize if i'm doing this wrong,I'm new to this. I have a 1997 accord 4dr. where is the sensor located? Also my A.C. is not working, has enoygh pressure in system but does not want toget cold , where should I start?Thank You,Scott
Old Jun 6, 2011 | 08:30 PM
VSS is located below and behind the distributor, just inside the thermostat housing. It is a bit difficult to remove due to near engine bolt (of 2) access. Do you have an ECU code 17 and/or TCU code 4?
Best way to diagnose AC system is to measure system pressures (high and low side) w/ an ac manifold gauge set. You can buy an inexpensive set for less than you'll pay someone to perform a pressure check. If you're reasonably handy, you can take pressures yourself. If you diy, this is a good place to start your AC eduction. Take pressures w/ engine speed at 1500-2000 rpm, AC on, Max Fans, Recirculate, and car parked in shade.
Check autoacforum.com for help on auto AC. This site solved lots of my AC problems. I haven't had any ac problems for several years due to good repair practice.
Old Jun 7, 2011 | 11:09 AM
Lightbulb Very Good Information Here
Also you can go to an AutoZone and rent that gage kit to use and when your done with it you even get your money back.. Way to save money.
Angelo
Old Jun 8, 2011 | 03:56 PM
KatraLa127's Avatar
How do you get the code from the ECU and TCU?
Old Jun 8, 2011 | 06:12 PM
Go to DIY forum and look up procedure to extract codes. Post codes for guidance.
dioalp
Jun 24, 2010 02:40 PM
94exsedan35094
Feb 5, 2008 08:44 AM
comptoncarl
Feb 8, 2007 03:04 PM
JWW512
Jul 23, 2006 01:04 AM
cbriley3
Oct 23, 2005 11:04 PM
