Vtec pressure valve
Old May 7, 2011 | 02:06 PM
Tek310's Avatar
Default Vtec pressure valve
I have a 95 f22b1 and need to replace the pressure valve. Where do I get them? Local part store don't seem to have them.
Old May 7, 2011 | 02:23 PM
You can get a new one from the dealership, but it is expensive. A junkyard is a good source for cheap used parts.
I'm guessing that you got a code 21. Did you do the tests on the valve as outlined in the shop manual? You can get a 94 shop manual from the links posted in the Online Manuals thread in the DIY section that will show the tests on page 6-4.
Old May 7, 2011 | 03:05 PM
Tek310's Avatar
No code 22
I have not done the checks. But it's kinda rusted so I wanted to just replace it. I will check the junk yards.
Old May 7, 2011 | 06:01 PM
The tests for a code 22 are after the page I referenced before.
Check that your oil level is not low and do the tests on the pressure switch described in the manual.
usedcarman
Feb 22, 2024 03:48 AM
eduard
May 9, 2013 12:11 AM
live2rice
Jul 10, 2011 09:05 PM
piconrule
Jul 24, 2009 02:38 PM
tb10594
Jun 3, 2009 08:53 AM
