Vtec Synchronizing Pin and Timing Plate
Hello. I am working on a 2001 Accord 2.3 vtec which someone had apart before me. I got it with a blown head gasket, and presently reassembling. On the rocker rail, all 4 Timing Plates were broken. Also, one of the Synchro pins/piston was sitting inside the head, and two more I believe were inserted backwards. Was wondering if someone can confirm that I have the Pin and Spring going in the right way, (spring to the Left, pic A), vs (pic B which I believe is backwards). Also I would like to confirm that I have my new Timing Plates on the Correct side of the Retaining Tab, (pics C and D).
Thank you much !
Thank you much !
Unless someone has experience to provide guidance, you may need to seek some help w/ Honda shop or some machine shops that specialize in head repair might help.
I checked honda shop manual, and these parts are shown as "intake rocker arm assembly" and no discussion of disassembly is provided.
I found a lot of images w/ google search for "honda vtec intake rocker arm". perhaps they may help.
If you don't have a shop manual, get a download manual from automanualsource.com.
Hey thanks. I had already even went to the Dealer Service Dept who allowed me to look in there shop manual. Nothing there. So far after 3 hours on the internet, no pics of that "particular" breakdown. I may just have to wait for someone who has one of these rocker rails off already who would be willing to carefully check how this is assembled, lol. Or as you suggested, go to a Machine shop who is familiar with Vtecs. Just surprised I can't find anything.
Thanks again !
Thanks again !
I remembered a detailed image of vtec arrangement from 1994-97 Accord Manual. It provides some details which appear to be similar/same as yours.
Go to Online Manuals post in DIY forum and download the 94-97 Accord manual. See Engine/Construction and Function (F22B1) section of manual for diagram. I tried to print a single image, but copy protection on PDF defeated me.
The info. is part of the 6th generation Accord service manual.
1. Based on the service manual, the rocker arm piston looks like it should be assembled like your picture B.
2. Timing plate appears on correct side.
Thank you all for the great info, especially to Redbull-1 for the pic. Going for reassembly with my Pic B and the above Service Manual pic. Will let you all know how it went, tomorrow.
Peace
Peace
Update: Well, it appears I did the Rocker reassembly correctly, however I cannot fully test it yet because something else went terribly wrong. My head gasket did not seal correctly or I got something else screwed up, because the oil milkshaked within just a couple of minutes. I have done over a 100 Honda heads, but only a couple 2.3 vtecs. seems all pretty much the same to me, and my first ever failure like this. Oh well, can't win them all. Time to get back in there and see what the heck I did wrong.
cengland84
Oct 28, 2008 01:20 PM
