VTEC valve noise
Old Oct 12, 2007 | 09:17 AM
mark_'s Avatar
Default VTEC valve noise
Hey guys,
I just adjusted the valves on my 2001 2.3 VTEC, this morning there still was some top end noise after a cold start. How much valve noise is normal? Are the VTECs a little more noisy than the non VTECs?
Thank you.
Regards,
Mark
2001 Accord 4 Door, 2.3L
Old Oct 12, 2007 | 11:33 AM
sir_nasty's Avatar
Default RE: VTEC valve noise
without hearing the noise I couldn't tell you if it's excessive or not. As long as you properly adjusted them (using the appropriate go/no go guages) it shouldn't be very loud unless you're low on oil or need an oil change
Old Oct 12, 2007 | 02:46 PM
mark_'s Avatar
Thanks Nasty...do the VTECS make a little more valve noise than other Honda engines?
Mark
Old Oct 12, 2007 | 07:38 PM
deserthonda's Avatar
ORIGINAL: mark_
Mark
not that i am aware of ..
when you first start the car up,, valves might be a bit noisier till the rocker arm assembly is fully ,properly lubricated ,, but it should go aways within seconds
But like Nasty said ,, it is a noise that one would have to hear to advice if it is too much or common ..
jfidelh
Feb 26, 2013 10:03 AM
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
IDRAGrockerPANEL
May 12, 2010 12:57 PM
huzzsaba
Dec 19, 2006 09:37 PM
