Water in brake lights
Old Mar 25, 2007 | 01:48 PM
I_heart_my_Honda
Default Water in brake lights
I love my '98 Accord EX, but recently (just a year or so ago), I noticed that whenever it rains or after a trip to the carwash, water pools in my brake lights. Then, the next time I open my trunk, the water exits from the inside of the trunk (from the hole where the electrical wires for the lights are). I have not been in any accidents, and no damage has been done to my car whatsoever. I don't know what to do except keep a bucket in my trunk and catch the water. Does anyone else have this problem? Any "simple" fixes? Thanks!!!!!
Old Mar 25, 2007 | 02:14 PM
Cody Is Cool's Avatar
Default RE: Water in brake lights
same thing happened to me. and when it rains or i get my car washed my tail lights have water in them. i have the same car
Old Mar 25, 2007 | 02:17 PM
There are two possibilities; the foam gasket that seals the lens assembly to the body is leaking, or the lens assy has an seam that has opened. I've had both happen on earlier model accords.
Foam gasket is readily avialable and easy to install.
To fix the open seam, I drilled a drain hole in the bottom of the lens to allow trapped water to drain, or you can purchase a replacement lens.
Diagnosing which is your problem is tricky. I replaced the foam gasket and found I still had a leak, so after some water trials, I decided the lens seam must be open, and drilled the hole.
rudeg
Dec 31, 2015 07:23 PM
csh217
Apr 30, 2013 09:03 PM
drive4fun
Aug 5, 2008 08:28 AM
98accord98
Sep 8, 2006 01:25 AM
