Water inlet hose A replacement
Old Jul 13, 2011 | 03:44 PM
capthoward's Avatar
Default Water inlet hose A replacement
I have a 2001, 4cyl, A/T, 187,000 Accord. Need to replace subject hose. The hose looks like a straight forward swap-out. Anything I need to know about replacing the lost coolant, air in the coolant system, etc, etc?
Old Jul 13, 2011 | 04:34 PM
Tek310's Avatar
there will be a bleeder screw on the thermostat housing. crack that open and refill radiator until it pours a steady stream and no bubbles. also have the temp **** set on max heat
then run the car with the cap off until the fans kick on, this ensures all air comes out of the system.
meggimann2000exl
Aug 17, 2011 10:53 AM
desfam5
Aug 23, 2010 03:33 PM
jamesejam
Sep 21, 2009 02:37 PM
thunder_x
Jul 13, 2007 04:20 PM
oldaccordman
Feb 4, 2007 04:46 PM
