Water leak in the trunk.
Old Aug 1, 2010 | 12:28 PM
ChicagoBob123's Avatar
Default Water leak in the trunk.
1993 Honda Accord.
I dont see the leak but I can feel the carpet in the center of the trunk is wet. This happened while the car was sitting in the driveway. I opened the trunk and felt water. Is it possible the rubber seal no longer meets the trunk lid?
The seal does not look like it has anything wrong with it.
Thanks.
Bob
Old Aug 1, 2010 | 12:40 PM
Oh how I hate finding leaks....not in the right tail light is it, might help with the brake light issue you are having. In the center is a bit strange. Crawl in if you can while the trunk in closed and see if light is coming in from anywhere. Then there is the baby powder method. I have not seen one in the center, if it was on the sides I could give some things I've found over the years...sorry.
Look also at the metal part where the rubber seal attaches. Kinda like a little raingutter around the trunk opening. Rust holes?
Crawl in the trunk with a flashlight & have someone pour water outside with a garden hose.
Old Aug 1, 2010 | 01:43 PM
deserthonda's Avatar
i have seen leaks from the tail lites gaskets,, replace those first,, there is a write up on DIY section
Old Aug 1, 2010 | 02:08 PM
Tail lite gasket? Maybe.. I will look at that by shooting a hose at it.
Maybe thats why the right tail light is giving me issue.
Thanks for the idea.
Old Aug 2, 2010 | 08:14 AM
Old Aug 2, 2010 | 09:20 AM
I think that Deserts link will be the way to find it..
Thanks Gianni
Agregory88
Dec 9, 2012 09:54 AM
thaison86
Jun 28, 2012 12:03 AM
imabadczech
Dec 1, 2010 06:41 PM
MNHONDAGUY
May 8, 2007 07:52 PM
deserthonda
May 12, 2006 03:06 AM
