Water in radiator seems to be forced out and no solution yet; need help.
Old Mar 25, 2011 | 05:36 PM
If you're losing that much water, it should be apparent on the ground somewhere or by very white smoke from exhaust. Have you looked at dipstick to be sure no coolant is entering oil. Coolant in oil can damage the engine.
Hopefully, it's just a radiator crack.
Old Apr 7, 2011 | 07:06 PM
mr_courteous's Avatar
Post Sad moments in the Honda world
Greetings & salutation my fellow accord owners,
I was out of the picture for almost two weeks. Well, I have the diagnostic results. According to the last Honda dealer mechanics, I've been driving with a bad head gasket. It was suggested to have the head gasket repaired but on the other side I can maybe have the engine replaced with a good used low mileage engine. Currently, the original engine has about 260K miles. This is where I will need for you to shed some light on this topic. Shoud I go with a good used engine or replace the head gasket? The other option is to get another Honda accord but this one will be more costly.
Your input is appreciated in this matter.
Thank you in advance. Yours truly.
Mr. Courteous
Old Apr 7, 2011 | 10:02 PM
I would replace the head gasket unless you know there are problems w/ the engine. Does it burn oil? Check the compressions. I've had engines w/ that mileage/age w/ new level compressions.
MikeSz
Jan 31, 2014 03:31 PM
tris320
Jun 16, 2010 11:08 PM
06EX_R
Jan 14, 2008 05:18 PM
Dr.Evil
40
Sep 17, 2007 01:23 PM
rtmobile96
Sep 16, 2007 04:14 PM
