Weird Backfiring/Missing (97 Acc. 4 cyl)
Old Nov 1, 2012 | 06:53 PM
Roader's Avatar
Originally Posted by Dualnames
I am going through about 2 quarts every 500 miles now.. still getting misfires. Any ideas on high oil consumption?
That's an awful lot of oil burning, if it's not leaking. A good way to differentiate between valves seals and piston rings is if after an oil change the oil darkens quickly, like within 500 miles. Oil getting sucked through bad valve seals doesn't darken the oil. Oil getting past the rings goes both ways, into the combustion chamber and back into the crankcase, loading the oil with combustion by-products and darkening the oil.
Old Nov 1, 2012 | 07:05 PM
UhOh's Avatar
Well ... I started slowly using a higher weight oil.
I tried that in past w/o success. better luck to you
1999HondaAccordEXV6coupe
May 19, 2013 06:59 PM
wheresbrando
Apr 10, 2012 11:00 AM
Stephenrod
Aug 25, 2010 01:12 PM
Mdschmidt
Sep 9, 2009 06:07 PM
jamrock
Feb 11, 2009 08:58 PM
