Weird, loud, annoying grinding sound
Old Apr 17, 2013 | 07:23 PM
ETH13's Avatar
Default Weird, loud, annoying grinding sound
There is a grinding and rattling sound coming from beneath the car. Now that the better is getting better, it is so much more annoying and unbearable. It is only there around 2000 RPMs and slightly around 4000 RPMs. It is really annoying. It is only there during accelerationI have read that it could be the heat shield or the catalytic converter. Is there anything I can try to do to fix this?
Old Apr 17, 2013 | 07:51 PM
Help us help you.....and a reason we ask members to put their car info in their signature line and "display signature".....what kind of car is this?
Old Apr 18, 2013 | 04:48 PM
ETH13's Avatar
2003 Honda Accord Ex 2dr v6
Old Apr 19, 2013 | 03:36 PM
Hamster108's Avatar
scrap it, its the only way you will get any money for it
Old Apr 20, 2013 | 09:23 AM
Can you get under the car - use safety - and look at the heat shields.
Old Apr 21, 2013 | 05:02 PM
ETH13's Avatar
How many are there?
Old Apr 22, 2013 | 07:51 PM
Well there are a few. The one(s) I would inspect first are around the "cats". There is an upper and lower shield. At the corners of the cat should be a bolt......four on top and four under. Give each corner of the shield (eight total) a push/pull and see if any are loose.
stockxplorer
Sep 25, 2022 04:15 PM
lotas
May 8, 2012 08:50 PM
argarcia86
Feb 13, 2012 07:21 AM
jaybeezi
Aug 6, 2009 07:10 PM
chibiko
Mar 19, 2007 04:03 PM
