what computer do I replace?
Old Mar 21, 2016 | 01:25 AM
rangerman83's Avatar
Default what computer do I replace?
So i was able to get my car smogged. The big problem I have with my car is that when I turn the car off and then back on, all the sensors get wiped clean. Then I have to drive it for about 50 miles before things start registering again. I was told by the smog tech that it might be my computer that is malfunctioning. So my question is what computer controls the emissions? Where can u find it and does anybody have a tutorial on replacing it?
Old Mar 21, 2016 | 09:29 AM
Dr. Drivability's Avatar
Sounds like you are losing your KAM (keep alive memory), you may want to have some diagnosis done before you through a PCM at the car. Do any other systems reset like the radio for instance?
I'd make sure I had good power and grounds at the PCM.
I don't see anything in the diagrams for a specific fuse for PCM memory.
Old Mar 21, 2016 | 12:33 PM
Under-hood fuse no. 39 (7.5A) is the battery back-up memory fuse.
Old Mar 21, 2016 | 01:38 PM
Ah...thank you Redbull
Old Mar 25, 2016 | 12:48 AM
Yes the radio resets everytime.
tkbalt
Sep 25, 2006 09:13 PM
Patrick
Feb 14, 2006 10:37 PM
99accordloaded
Sep 29, 2005 09:26 PM
Evlampius
May 31, 2005 12:56 PM
Evlampius
May 4, 2005 02:49 AM
