What could be broken?
Old May 23, 2007 | 11:00 PM
peewee's Avatar
Default What could be broken?
Hi, today when I was driving the Accord it would seem that something broke, and now the clutch no longer disengages. Ended up starting it in first with the starter pulling the car until it fired up, and clutchless shifts all the way home. Nasty but it got me home!
I have the skill to fix this, but I'm curious as to what could have broke? My buddy who helped with the new clutch told me maybe the clutch fork broke...but I'm wondering what else it could be? I dont really have the heart to junk it yet, thats for sure. I would appreciate some input here...thanks.
Old May 23, 2007 | 11:32 PM
Default RE: What could be broken?
Watch the throw-out fork while someone pumps the clutch pedal for you. If it moves 12mm or so, then the problem is inisde
Old May 24, 2007 | 09:58 PM
peewee's Avatar
I had to use a video camera but I seen no movement at all. So clutch master or slave cyclinder maybe??? I have three days to fix it this weekend....
Old May 24, 2007 | 10:57 PM
Rhoderman's Avatar
Check the linkage that goes between the pedal and the master cylinder. If you felt/heard something break, it might be that simple.
I snapped a cable on my S-10 4x4 years ago. Luckily I walked back and found the piece of cable that fell off. Would have cost me more if I had to buy the part that screwed onto the end of the cable too!
Open the bleeder screw at the slave (if there is one) and see if you can get fluid to come out when you pump the pedal. No fluid = bad master (or no fluid in master, but I'm assuming you checked that). Usually when a slave goes out, you lose all the fluid in a hurry.
HTH,
Jim
Old May 26, 2007 | 08:32 PM
peewee's Avatar
I guess my video was bad. The slave does move the clutch fork about an inch. I need to put on my new slave cylinder anyway because the bleed screw broke but it must to be something internal. Is there a was to do this without pulling the trans? Some way to maybe just back it off a few inches?
Old May 28, 2007 | 10:18 PM
Almost certainly you gotta take off the tranny & look around for what's broken in the clutch.
Old Jun 18, 2007 | 04:40 PM
peewee's Avatar
Turned out that one of the clutch springs broke out and got stuck in the pressure plate. Also, the sleeve that the TO bearing rides on was VERY worn, and broken off. You can see it sitting in the bellhousing.
Old Jun 18, 2007 | 09:29 PM
wietgr's Avatar
Yea that'll do it everytime, that slevee is F[:'(][>:]ed Up!
Old Jun 18, 2007 | 11:20 PM
Wow, that's spectacular. Thanks for posting back with the final story, lots of people just disappear & we don't know if we were any help.
When something like thatbreaks, you just have to take it apart & look around.
RONAN
Feb 26, 2007 10:29 AM
TxOutlaw
Aug 22, 2006 05:49 AM
Mpwr
May 12, 2006 04:14 AM
redwaterfried
Dec 24, 2005 04:21 AM
