What does it take to fix the climate control cable?
Old Feb 2, 2013 | 06:24 PM
93Accord2.2's Avatar
Default What does it take to fix the climate control cable?
It's a 1993.. I had to change it manually under the hood... I believe that's called the heater control valve??? But I am going to be selling the car, and people will probably make a "big deal" out of that if I don't fix it.
When it stopped working correctly, at first I could get it to change by moving it very quickly. But I'm pretty sure that the cable has broken.
Should I buy a new one, or try to salvage it?
Can I get to it fairly easily?
Thanks!!
Old Feb 2, 2013 | 06:30 PM
I moved your help thread to the General Tech Help section. Please read the forum rules and do not post in the DIY section.
Old Feb 2, 2013 | 07:17 PM
I'm sorry- I thought I looked for the best section, but I obviously should have looked more closely!!! Thanks for not deleting it
Old Feb 3, 2013 | 08:24 AM
You say it is not moving, so I can assume it does not have a broken end at the valve????
A few things you need to check.
Are you sure the **** is not broken....yes they break.
Then check that the blend door cable is moving...from the pass side floor board, look up at the bottom of the "heater/evap" case, might be a cover over it, can't remember on the 4th gens.
If that is moving be sure the heater control cable is attached to the "other" end of the blend door arm? is it?
Old Aug 5, 2013 | 03:08 PM
The cable seems to be just completely broken.. Turning it doesn't do anything and there's no tension on it, but I can see that it's not broken at the hcv by the firewall. . . I don't care but if I ever want to sell it, I suppose I should fix that
pr1madona
Feb 23, 2014 11:26 AM
thewraith
Oct 26, 2008 07:00 PM
greenbean
Sep 21, 2007 03:14 PM
thunder_x
Jun 18, 2007 05:38 AM
