What else can I do?
Old Nov 29, 2012 | 09:21 PM
pani's Avatar
Question What else can I do?
98 Honda Accord EX, 4cyl,AT
My honda is idling erratically 1000 to 2000 rpm no CEL
I did clean the IAC-valve,washed the TB,changed the TB gasket,bled the coolant valve,sprayed carb cleaner everywere to check for vacuumleak. When starting the cold engine it idles very high and when it warms up it starts to run erratically. When trying to adjust at the idle screw there is no change in the idle speed.. When unplugging the IAC plug it keeps idling erratic but lower and when I cover the hole in the throttle body with my finger only then it idles normally.
Can someone please tell me what else to do?
Old Nov 29, 2012 | 09:59 PM
Silver6gen's Avatar
The problem is not the idle screw. Don't mess with it anymore.
So you replaced the TB gasket huh? It sounds like you have an intake manifold leak / vacuum leak.
When it goes from 1k to 2k does it rev up then drop then rev up over and over again? That is classic Vacuum leak symptoms.
Old Nov 30, 2012 | 07:18 AM
pani's Avatar
That is exactly what it does. Can you explain to me where else to check for vacuum leak? It started to do this after changing the headgasket. Can you detect a leak on the intake manifold by spraying carb cleaner on it?
Old Nov 30, 2012 | 07:22 AM
jroxz44's Avatar
Almost A Senior Member
My car does the same thing if I let it sit for acouple days then run it. It stops thou after running it for a day. Also check your fast idle valve. They need screwed in from time to time. Depending on what year your accord is. There is acouple threads in the DIY section about it
Old Nov 30, 2012 | 08:12 AM
Silver6gen's Avatar
Yes,
the revving is not caused by the head gasket. It is a breach in the intake manifolds ability to hold vacuum
Old Dec 19, 2012 | 10:06 PM
pani's Avatar
Originally Posted by Silver6gen
Yes,
It has been a long time ago. I had to travel for my work and now I am back on it. I have talked to a friend about the problem of the up and down idling of my honda when it warms up and I also told him that i took the AIC-valve apart to wash it. He told me that that might be the problem and that I was wrong in loosing the plastic part (spool) from the metal part to clean it. He said to me that there is a way to adjust it but he doesn't know how to do it. Is there someone who can explain me how to adjust it back the way it must be?
Old Dec 21, 2012 | 05:54 PM
Just me but if the plunger/stopper is missing then you are looking for a new/used IAC.....Got pic's of the piece that was lost, just want to be sure we are talking the same thing.
Don59
Jan 1, 2011 12:00 PM
02BlueAccord
Dec 4, 2006 11:38 AM
emaxxman
Mar 31, 2006 02:45 AM
magicpenguins01
Jan 13, 2006 01:07 PM
