What happens if you mix different oils
Old Jun 2, 2015 | 10:37 PM
richard9's Avatar
Default What happens if you mix different oils
Is it acceptable to mix oils.
For example if you have 4 quarts of Quaker State 5w-30, can you mix with one quart of 5w-30 Castrol.
If you have one quart of 5w-30 quaker synthetic blend, can you mix with 4 quarts of 5w-30 quaker state oil
Thanks.
Old Jun 3, 2015 | 04:12 AM
shipo's Avatar
Yes, no issues.
Old Jun 4, 2015 | 09:48 AM
Corvair's Avatar
Been doing it for decades. My poor Corvair has had 5w-30, 10w-30 and 10w-40 at the same time. It seems like every time we get a new car, it uses a different weight and end up with a case or two of something I don't need anymore. I have a couple cases of 5w-20 from my Fiesta. Too light for the Corvair as it runs over 200 degrees. Our Hondas both take 0w-20, and I not going to risk putting it in them.
Old Jun 5, 2015 | 11:54 AM
Prospector's Avatar
I would advise caution when mixing oils from different manufacturers as some additives may be incompatible
Old Jun 5, 2015 | 02:16 PM
shipo's Avatar
Meh, every manufacture has a FAQ on their web site, and last time I checked, they all stated they were compatible with pretty much every other contemporary oil except Group V (ester based) Synthetic oil.
Old Jun 7, 2015 | 03:04 PM
woody31's Avatar
Almost A Senior Member
Any oil is better than no oil, I ran 10-30 and 15-40 in my elcamino and it didnt know the difference. Hell it was just happy to have oil in it. No issues.
Old Jun 7, 2015 | 05:57 PM
shipo's Avatar
What you say is very highly likely for any generation of El Camino engine what with the exceedingly loose tolerances and such; put 15W-40 in a modern Honda engine and all will not go quite so well for the motor.
Old Jun 7, 2015 | 08:03 PM
woody31's Avatar
Read my post,,any oil is better than no oil...it was a hi performance built 362 cubic inch small block and i assure you it was not loose... 96 vortec block bored .060 vortec heads. ect,,ect,,/ ANY OIL MIXED OR NOT IS BETTER THAN NO OIL,,in a pinch i have run the same 15-40 delo in my accord with zero issues, you have a right to your opinion but what you say is not sacred by any means..carry on.
Old Jun 7, 2015 | 08:53 PM
shipo's Avatar
You missed my point, at its very best, your small block Chevy motor has no were near the close tolerances of a modern motor.
tracemiller
Aug 28, 2008 06:14 PM
kriegz99
Aug 11, 2007 08:41 AM
JimBlake
Aug 5, 2007 08:28 PM
mpanelli
Jun 21, 2006 08:55 PM
Mulaka
Apr 24, 2005 01:14 PM
