What Model Engine do I have in a 2000 Accord EX...?
Old Mar 23, 2015 | 01:29 PM
NorthCountry's Avatar
Default What Model Engine do I have in a 2000 Accord EX...?
I recently picked up a used 2000 Accord EX with the 4cyl 2.3L motor for my daughter.
When looking up parts I see there are 3 engine choices:
4cyl - 2.3L F/inj. (16V) SOHC F23A1 V-Tec
4cyl - 2.3L F/inj. (16V) SOHC F23A4 V-Tec
4cyl - 2.3L F/inj. (16V) SOHC F23A5 V-Tec
How do I know which model engine I have?
Thanks!
Old Mar 23, 2015 | 01:50 PM
EX can be F23A1 or F23A4.
The ULEVs had F23A4 engines, while the non-ULEV had F23A1 engines.
Does the engine valve cover says ULEV? Even if it does, there is always the remote possibility someone did a partial swap where it was a F23A1 engine block with just a ULEV valve cover (that happened on this forum before).
You can also enter the car''s VIN on sites like Bernardi Honda Parts to get some info.
Old Mar 23, 2015 | 02:26 PM
shipo's Avatar
If I recall correctly, the ULEV (or LEV) sticker is attached to a window on the left side rear door.
Old Mar 23, 2015 | 04:21 PM
Serial # pad is machined into the front side of the engine block, about mid-elevation, right where the engine & transmission split from each other. Top line is the engine (F23A1) second line is the block serial number.
With any 14-year-old car you have to think about a previous owner swapping engines.
The exhaust manifolds look quite different from each other. Take a photo & post it?
ps... the F23A5 engine is non-VTEC and comes in the Accord DX model.
Old Mar 23, 2015 | 07:39 PM
Thanks for the replies guys. No sticker in any window that means anything related to the engine from what I can tell. Couldn't find anything machined into the block. Here's some photos... no idea if it's the original engine or not, 155,000 miles. Thanks!
Attached Thumbnails What Model Engine do I have in a 2000 Accord EX...?-1.jpg   What Model Engine do I have in a 2000 Accord EX...?-2.jpg
Old Mar 23, 2015 | 07:44 PM
Your daughter's car probably a F23A1, non-ULEV.
This is what a ULEV normally looks like. The engine code is at the area indicated.
Old Mar 23, 2015 | 08:47 PM
Great information and photo. Thanks redbull! It does look a little different than your photo so like you said, most likely a F23A1. I take another look for the engine code tomorrow. Thank you!
Old Mar 24, 2015 | 11:10 AM
It is F23A1.
The exhaust manifold & A/F sensor is clearly not F23A4 in your photo (you see the difference from Redbull's photo).
And I can't find the F23A5 (non-VTEC) for 2000. I wonder if that engine was discontinued after 1999???
Old Mar 25, 2015 | 10:24 AM
Thanks again for all the replies and help from everyone that posted.
F23A1 it is.
f_mehmood1982
Feb 7, 2013 07:20 AM
davidg99
May 5, 2011 11:59 PM
danielwebb
May 18, 2010 02:58 PM
LXn1TR0
Dec 11, 2007 08:48 AM
