what o2 sensor?
I got a p0134 rear air fuel ratio sensor bank 1 code on scanner. What o2 sensor do I buy. I'm ordering from rockauto. Can someone help? Guy quoted me 53 dollars. Seems kinda low. I wanna make sure I get the right one. I live in Hawaii. Parts are hard to get. Can someone tell me the exact one or post a link. Thx and aloha.
I think yours is the same as mine. If that's the case, then there are two upstream sensors (aka "Air fuel ratio sensor") and two downstream sensors (aka O2 sensor). One pair for each of the warm-up catalytic converters to either sides of the engine block. The cat converter underneath the car doesn't have sensors. The upstream sensors that are direct-fit usually cost $100 each, much more than the downstream ones it seems.
Check out advance auto parts, they have very nice coupons ($50 off $150). Make sure you get the one that fits your vehicle.
P0134 is for bank 1, sensor 1.
Looking from the front of the car Bank 1 is the REAR (firewall) and Bank 2 is the FRONT (radiator side).
This shows the different sensors:
https://www.hondaaccordforum.com/for...r-location-jpg
For part numbers, online sites such as advance auto parts or Amazon have their own matching system, so you punch in your car model and year, and they will let you know if something fits. But as a safest bet, I would just call the dealership. You don't have to buy them, unless the dealership acts up, in which case call another. Good luck!
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
