What is this part?
Old Apr 26, 2016 | 08:05 AM
honda4fam's Avatar
Default What is this part?
Can anyone tell me what this part is? Can't figure out how to post a picture? It is the triangular piece with the round part on top with three bolts under the round piece. It is in the right side of the engine just behind the valve cover. It is leaking oil. It is on a 4 cylinder 1996 Accord.
Old Apr 26, 2016 | 06:16 PM
If your accord is an EX, then that is the vtec solenoid. There are two gaskets that can be leaking. An oring under the triangular plate, or the gasket that seals to the cylinder head. It is the easier of the two to replace. To remove from the cylinder head, I highly recommend removing the thermostat housing. You will be tempted to use a 10mm boxed wrench on the lower bolt, and you run the risk of stripping that bolt. Guess how I know?
Old Apr 26, 2016 | 06:17 PM
Sound like the vtec solenoid. There are two sets of o-rings you can replace to reseal it and you should be good to go. From the dealer, my memory tells me they are about $20 in total.
EDIT: I see PA posted as I was typing
Old Apr 26, 2016 | 06:54 PM
#10 and #12 are the o-rings/gaskets you need for the solenoid.
Online they are like $9 and $3, shipping might kill you. Local dealer will be about twice that price. I think I've seen these in the aftermarket but can't remember where (Dorman Products ?).
#10 is 15825-P0A-015
#12 is 36172-P0A-005
emaxxman
Apr 6, 2006 03:24 AM
HONDA90
Nov 2, 2005 05:57 PM
adbraz
Aug 23, 2005 01:30 AM
Thep
May 4, 2005 09:38 PM
