What is this part next to the fuel rail. Some kind of vacuum/sensor
Old Jan 18, 2021 | 09:11 PM
Brandon Jaap's Avatar
Default What is this part next to the fuel rail. Some kind of vacuum/sensor
I have a 2004 Accord EX 2.4 automatic. This part where the vacuum hose connects broke and I have no idea what it is called. It is sitting right next to the fuel rail and the wire from the injectors also connects to it.
Old Jan 19, 2021 | 10:08 AM
Back up a little bit with the camera - it's hard to tell where that is.
It looks like the "electronic control solenoid" (50391-SDA-A01); #9 in the picture. Not a very descriptive name...
I'm going to move this to General Tech. We use the DIY section for finished write-ups, not for questions like this.
Old Jan 19, 2021 | 10:23 AM
That is the engine mount control solenoid valve.
Accords with automatic transmission have a vacuum assisted engine mount. It is used to control excessive vibration at low rpms (e.g. idle). At low rpms, the PCM sends a ground signal (-) to the engine mount control solenoid valve, which opens the valve.
Old Jan 20, 2021 | 11:11 AM
OK, now I can show where the hoses are supposed to connect (just in case that was part of your real question...)
The solenoid is at the upper left; and the front engine mount is #9 and the hoses are shown here.
Justin Dreyer
Nov 28, 2018 08:15 PM
lothian
Nov 29, 2017 07:13 AM
cukaracha
Jul 17, 2014 04:05 PM
TexasHonda
Nov 2, 2013 07:42 AM
techjohnny
Feb 20, 2011 09:22 PM
