what is this? should it be like this?
Old Jun 6, 2009 | 11:31 AM
mayojuaf
Default what is this? should it be like this?
Working on the heater control valve as the clamp went loose and the valve did not shut completely (sending hot air even the **** was set to cold) I discovered this open tube. Is something missing on the top? should it be open like it is?
I tried to paint an arrow but did not do a good job so I circled the part
thanks in advance for any help
Attached Thumbnails what is this? should it be like this?-accord-engine-4.jpg
Old Jun 6, 2009 | 11:33 AM
mayojuaf
sorry, forgot to mention is an Honda Accord 1999 LX 2.3L manual transmission.
Old Jun 6, 2009 | 12:59 PM
Fuse's Avatar
It is your manual transmission vent. You trans heats up and builds pressure it need to be relived or you will blow out seals. So its just a hole that need to be open. I think the tube should be bent to help keep out water but that should be fine.
Old Jun 8, 2009 | 06:35 AM
I think there should be a special rubber cap on that, which has a little vent hole facing down or sideways or something.
Old Jun 10, 2009 | 04:04 PM
mayojuaf
Thank you guys. will go to dealer and get one. Probably not good to have that openning for dust and moisture
Old Jun 10, 2009 | 04:49 PM
"Breather Cap"
SandMan
Sep 22, 2007 12:33 AM
Trey
Nov 30, 2005 02:03 AM
dinzer
Jun 7, 2005 01:07 PM
6thgen
May 26, 2005 11:40 AM
Mulaka
Apr 24, 2005 01:14 PM
