What to use to lubricate weatherstripping?
Old Nov 1, 2012 | 11:13 AM
MessAround's Avatar
Almost A Senior Member
Default What to use to lubricate weatherstripping?
So I want to get pre-emptive on weatherstripping. Anyone here know if Honda recommends certain things for weatherstripping?
I've done a bit of research and I know petroleum based greases or lubricants are off consideration since they can swell rubber. So I'm thinking some kind of rubber-safe silicone grease like AGS Sil-Glyde would be perfect since it's designed not to swell rubber on places like the rubber boot on a caliper slide pin. I figure I'll buy those packets of those at the local AutoZone, smear them on a q-tip and leave a thin non-visible layer inside the run channels so the windows go up smoothly without attracting any kind of dirt or gumming anything up. I plan on running a dry Q-tip up and down the channels to spread/stretch that tiny bit of silicone paste as thin as possible. The goal being not to leave globs of it, but just wet the run channels with the grease so it stays moist.
Then I'll do the same thing on the thick rubber that seals the doors where you open/close them.
Anyone tried this before and thinks this is a bad idea?
Old Nov 1, 2012 | 12:04 PM
Roader's Avatar
I used silicone faucet grease from Home Depot/Lowe's. About three bucks for a small plastic tin, enough to do four doors. IMHO the important thing is cleaning out the dirt from the channels with soap and water and an old toothbrush first and letting it dry out before applying the silicone grease. You'll be amazed at how much black crap comes off of them. A year and a half later my windows are still going up and down fairly fast.
bigdawg74
Sep 25, 2010 07:42 PM
bigdawg74
Jan 10, 2009 11:30 AM
nafango2
Jun 29, 2008 12:00 PM
BenJoeM
Nov 11, 2007 01:13 PM
91boz
Dec 4, 2006 06:04 PM
