whats leaking??
Old Nov 23, 2011 | 02:47 PM
madadam's Avatar
Default whats leaking??
I have a 02 rhd accord and am having timing belts and water pump/seals done on Sat, also gearbox oil.
I just made sure the filler/drainer are pentrated with fluid and can see a thin film of oil all over engine brace, wishbone and drivers floorpan area. not dripping, just a film. not dripping on ground and fluids seem to be stable. PSF dropped a bit but only 50ml in 2000miles. Any ideas would be gratefully received (not too expensive please)
The oil seems very light dont I think it is engine oil.
The boots around the drive shafts and the steering arms seem dry but i cant get right under the car to have a close look.
Anyone had this before?
I intend to degrease before it goes to Honda just in case they find a whole heap of trouble.
Thanks
Old Nov 25, 2011 | 03:39 AM
madadam's Avatar
Default Whats leaking?
Just been to Bristol Honda for a service and they confirmed possible rack leak along with a few split boots and a ball joint gaiter split.
Costs? not bad for boots/gaiters fitted - but rack, whoa. BUT, technician did say they would be prepared to fit a recon unit or aftermarket one - this surprised me, he told me how much a new honda one cost (nearly more than i paid for the car) but then said they would have no worries either reconditioning mine or fitting alternative. I was ready for the old hard sell tactic, but seeing as the MOT is in March, he said keep an eye on PSF over winter - so obviously its not unroadworthy.
Old Nov 25, 2011 | 04:00 AM
UhOh's Avatar
Originally Posted by madadam
rack leak
yeah, son has a 1986 Prelude with same power steering fluid leak.
it seems the cost to replace was expensive.
Son's solution is to keep a bottle of PSF in trunk and check it monthly - and to keep a drip pan under the car at home.
has driven it 3 years so far.
Old Nov 25, 2011 | 08:33 AM
Occasionally, PS leak sealant (Lucas in particular) will cause rack end seal leaks to stop. Meanwhile PS fluids is cheap, so unless UK motor permit rules don't allow leaks, living w/ the leak will be the low cost solution.
firefighter44
Feb 22, 2013 06:38 PM
filibuster
Aug 7, 2006 07:48 PM
Illusive
Jul 30, 2006 02:10 PM
St3v3
May 14, 2006 04:05 AM
xbombtek
Jan 29, 2006 08:19 PM
