Wheel bearings
Old Oct 1, 2008 | 11:53 AM
Sublime69
Default Wheel bearings
I have a 94 accord and i need to replace the front wheel bearings, has anyone ever done it? If so are they pressed in? Any thing i should know before i change them?
Thanks
Old Oct 1, 2008 | 12:14 PM
Default RE: Wheel bearings
See DIY section for "Replacing Rotors ( Hub over Rotor Setup )". This describes how to access the rotors, which requires removing the wheel hub assy. Once you have the wheel hub assy, you can take to a shop to have new bearings pressed in, or you can purchase (probably cheaper) wheel hub assys w/ bearings aleady installed.
I have used a slightly different procedure to remove the wheel hub assy from the knuckle. It uses long bolts and a hammer to drive the wheel hub assy from the knuckle. If you're interested PM your email address and I'll forward the procedure. It's a download from a newsletter that is no longer online.
oma93
Dec 10, 2007 09:21 PM
advokat
Oct 15, 2007 10:54 PM
dexter1
May 30, 2007 08:02 PM
panamared
Apr 6, 2007 02:08 PM
BigMike
Oct 21, 2006 11:31 PM
