When to change plugs
Old Oct 17, 2011 | 09:36 PM
UhOh's Avatar
Originally Posted by rio
Don;t mind spending the 9.82 - just didn't know if they were that much better than others.
Think I should change wiring too at this point?
Iridiums are my choice these last 5 yrs, cars and motorcycles.
But don't try to increase the gap on them, 'cuz the stiff little iridium posts just break off.
Can decrease gap as desired, tho. Me, I just throw 'em in (as purchased) w/ anti-seize on the threads.
Also just me, I don't change wiring till I have a problem; doesn't sound like you have a problem...
Old Oct 18, 2011 | 05:39 AM
There is no high voltage wiring as was the case w/ a distributor. The COP's are not a maintenance item, but will fail occasionally. Usually when spark plug gaps have gotten too large.
Old Oct 18, 2011 | 11:37 AM
deserthonda's Avatar
don't use anything but NGK or Denso plugs anything else is crap on Hondas
remember that they are going to last you another 100k miles , so the extra money on NGK or Denso will be well spent
Old Oct 20, 2011 | 07:04 PM
Hewmunga's Avatar
Cool
Just thought I'd add to this thread. I recently changed all 6 spark plugs in my 04 Honda Accord at 90,000 miles. I hope this helps anyone thinking about changing their spark plugs
Attached Thumbnails When to change plugs-imag0618.jpg   When to change plugs-imag0617.jpg
Old Oct 21, 2011 | 12:56 AM
The OEM Honda spark plugs are NGK or Denso.
You can get NGKs at most parts stores for around $10 a spark plug. I usually change by the mileage and not the time.
For the 03-07 4 or 6-cylinder, the NGK plugs you want are IZFR6K11. Only use these plugs, nothing else.
There is a sticker either under your hood or on the driver's door jamb with this information. The owner's manuals should have this information.
Old Nov 18, 2011 | 05:32 PM
accordado's Avatar
I bought 4 NGK Laser iridium IZFR6K11 part # 6994 at autozone for $9.99 each the same as the honda dealer asked $21,30 if i`m not wrong.This are oem and i will replace it tomorrow if is not raining that can be done in about 1 hour easily.Remove the plastic cover,the coil plugs and with a flash light u can see them allllll the way down inside the valve cover or whatever u guys call it.Tip:be carefull to not let the spark pulg socket get stuck in there and this will be a pain in the neck to take it out unless you have pacience and a lonnnnng neck ply i will use same gray tape and cut the rubber tthat holds the spark in half and take some pics and post is here and also change the air filter.
62maxx
Oct 18, 2015 08:20 AM
black94EX
Feb 13, 2012 06:58 AM
torrguy
Jul 18, 2011 06:01 AM
62maxx
Nov 21, 2006 12:04 PM
