Where is the AC condensate drain?
Old May 9, 2007 | 05:08 PM
Cavalry
Default Where is the AC condensate drain?
The G/F is complaining of moldy AC smell. I took a look and see no drain tube for the AC anywhere sensible. Where are they hiding it? Its a 05 coupe 4 cyl.
Old May 14, 2007 | 02:59 PM
Cavalry
Default RE: Where is the AC condensate drain?
Anyone know?
Old May 14, 2007 | 03:45 PM
incountry's Avatar
check your ac air filter
Old May 14, 2007 | 05:34 PM
hondadude's Avatar
I know, I know
It comes thru the fire wall on the passenger side just above the rear sub frame.
Change the evaporator case air filter, then run the air on "fresh" to help clear out the mold smell.
Also when your girlfriend is almost to where she is going, shut off the A/C to let the Evap case get rid of extra moisture.
Old May 15, 2007 | 02:08 AM
kturnerga's Avatar
Hello
There should be, at the passenger's floorboard, a tube fastened to a hopper-like device (the evaporator) if it is like earlier models. If it is particularly wet or stinky near there and the hose will slide off (don't cut hoses) remove it and force air into the hose headed out to the firewall.Be careful using wire to unclog; don't do that if you are going to the evaporator side of the system.
I would advise spraying a odor knock-out spray or a Clorox/water mix (protect your carpet first) in the vents and the A/C intake near the windshield wipers. I had to do that a few times.
KT
jon02accord
Mar 26, 2008 10:54 AM
hondafreak2
Dec 15, 2006 06:43 PM
92Inspire
Aug 29, 2006 04:08 PM
Ronin_301
Jul 5, 2006 12:54 AM
desi01
Jun 24, 2006 05:49 AM
