Where should i start from stock ? help!
Old Feb 15, 2013 | 04:08 PM
  #21
shipo's Avatar
Originally Posted by Gmez1407
Wouldent it be easier if i swap the transmission along with a h22a?
Swapping the engine, the engine and transmission, or just the transmission itself isn't really the bigger issue. Where you're going to run into trouble is the clutch pedal assembly and the linkage (which I believe is hydraulic).
Old Feb 15, 2013 | 04:59 PM
  #22
Gmez1407's Avatar
So it looks like im S.O.L
Old Feb 15, 2013 | 05:03 PM
  #23
Gmez1407's Avatar
So what does that leave me with as far as routs i can take with the car i have
Old Feb 15, 2013 | 06:53 PM
  #24
shipo's Avatar
Flipping into what I call "Standard advice mode"...
Your situation isn't at all unusual (pick pretty much any forum, this one, other Honda forums, and forums for Toyotas, Mazdas... and you'll find posts from folks wanting to do the same thing as you); the best advice I can offer is to keep the car you have, keep it stock which will keep its resale value as high as possible, and then save your hard earned money for a car you really want (you know, more powerful, better handling, nicer compliment of goodies, more prestige). Once you're ready to go, sell it for as much as you can get (as I said before, cars which are bone stock fetch higher resale prices than cars which have been mofified), and buy the car of your dreams.
Old Feb 15, 2013 | 08:41 PM
  #25
I'll argue the other way. Not because I really believe it, but just to play devil's advocate...
With experience and a bunch of tools, it's an interesting project to swap in a manual transmission. I said PROJECT. If you're simply interested in the end result of having a manual, then trade cars like shipo says. That's the path that really makes sense for most reasonable people.
But if you enjoy the PROJECT, take some time & do the homework. There's a lot of piddling little parts to change, from the instrument cluster to the pedal assembly, to half the guts underneath the console/shiftlever. And you'll end up with a little bit of a frankenstien because you probably won't change the car's wiring harness. You'll do a little ghetto work for brackets to hold the clutch hydraulic line. But it can be interesting if you can afford to be without a car for awhile.
I think there's 1 or 2 threads around here about swapping to manual. I know there's a couple regulars that have done it. And they have stories about the headaches they went through.
Old Feb 15, 2013 | 08:45 PM
  #26
Its not impossible by any means, but its definitely not something for a novice. And even for a pro it is by no means a fun job. If you could find a crashed or blown car on craigslist from your year with a manual transmission you could swap it all over and it would be cheap. Just time consuming.
Old Feb 15, 2013 | 08:57 PM
  #27
shipo's Avatar
I cannot argue with either of those two comments; I *wish* I had the time to convert my Accord to a 6-Speed manual; if I could then the only thing left to complain about the car would be the lack of an Outside Air Temperature indicator in the instrument cluster.
Old Feb 15, 2013 | 09:32 PM
  #28
Gmez1407's Avatar
Thanks for the great advice. But im just gonna go with what shipo said, ill be better off in the long run to just save up for a car that already has what i want like a prelude
Old Feb 15, 2013 | 09:34 PM
  #29
Gmez1407's Avatar
On a final note. What could i do to put a little more pep in my car without blowing up my transmission lol
Old Feb 15, 2013 | 10:18 PM
  #30
The prelude came with an automatic transmission that you may be able to swap. Using the 96 prelude ECU will keep your car obd2. I remember reading something about the prelude engine having 180 hp with the automatic transmission, but that could be bad information I read.
Take your time and do your homework so you will encounter less headaches when modifying the car.
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Renditions
Oct 16, 2012 03:37 AM
Yoshimitsu
Oct 4, 2012 05:51 PM
mamtsberg
Mar 17, 2010 09:15 PM
