wheres my oil going?
Old Jun 13, 2011 | 11:20 PM
honDUHchick's Avatar
Default wheres my oil going?
i just recently replaced the head on my 98 accord 4 cyl vtec. it runs great now, but there was a ton of sludge in my intake before, and i am still going thru oil even after its fixed... im not leaving puddles under my car, and i dnt believe its burning.................tell me theres a different issue and that its not continuing to go into my intake.
Old Jun 13, 2011 | 11:24 PM
How fast are you losing oil?
Have you replaced the pcv valve?
Old Jun 13, 2011 | 11:27 PM
yes i have replaced the pcv valve, its still good, and i prolly go thru about a quart every one to two weeks
Old Jun 13, 2011 | 11:34 PM
How many miles have you put on the spark plugs since you put the engine back together? Have you pulled a spark plug to check its condition? Do you see any oil on the outside of the engine block?
Old Jun 14, 2011 | 01:05 AM
zZHellBlazerZz's Avatar
I have been experiencing this same issue with my 94 Accord 2.2L VTEC, I found that it's leaking slowly from the back of the valve cover, it never hits the ground as it's too slow and only seams to leak when running... Check for wet areas all around in the engine compartment... It's got to be going somewhere, and if you can't smell it in the exhaust, I would say it's got to be leaking.
Old Jun 14, 2011 | 05:47 AM
piggylover1985's Avatar
Did you check the smoke coming out the tail pipe to make sure that you're not burning the oil because of worn rings? I had the same problem before, burning about 1qt every 300 miles.
drew&dixon1718
Nov 28, 2011 01:52 PM
Haggis
Feb 6, 2010 08:36 PM
shabba
Sep 17, 2009 04:43 PM
markinchico43
Jan 20, 2008 08:34 PM
tony11
Nov 4, 2007 08:39 AM
