Whining noise!
Old Nov 14, 2014 | 09:05 AM
CWilli's Avatar
Default Whining noise!
I hear a whining noise every time I turn the steering wheel on my 2008 Accord. What could it be?
Old Nov 14, 2014 | 11:15 AM
4-cyl? V-6?
Check the belt tensioner. There's some markings on the tensioner to indicate the belt stretched to its limit where you need a new belt.
Another way is carefully spray some water on the belt & try the steering. If that makes it quiet, you know it's the belt rather than something more complicated. Sometimes old belts get hard & slippery even if they aren't stretched too far.
One possibility is leaking O-rings at the hose connections at the pump. They let a bit of air into the pump.
Search around the General Tech. forum because someone has posted a tech. bulletin (maybe PAHonda?)
Old Nov 23, 2014 | 03:07 PM
Hello New Member and Thank You for joining the HAf..
96hondaaccord
Aug 11, 2006 01:36 PM
wj2
May 25, 2006 05:07 AM
wj2
Sep 16, 2005 03:10 AM
Jun 16, 2005 10:54 AM
cgarcia275
May 15, 2005 07:47 PM
