Whining noise on cold start up
Old May 13, 2011 | 05:06 PM
You don't test the ECU, you test the wires that mate to pins 11-12 on the connector side. Orn and Wht should be one over other. Looking at pin side of connector, they should be on RH side. You are testing for same ohms you got at the distributor connector.
Old May 13, 2011 | 06:13 PM
Tek310's Avatar
It is a 95 f22b1 auto
So I test the connector? Same numbers? Pin 11 and 12?
Old May 13, 2011 | 07:31 PM
Yes, those are the pins (actually sockets on connector side).
Old May 13, 2011 | 11:38 PM
Tek310's Avatar
I'm not getting a reading.. I'm doing this wrong. It's irritating. I dont get a reading on any of the pins
Old May 13, 2011 | 11:57 PM
Connector A has 22 pins, B has 16, and D has 22.
If you are looking at the ECU and A is on the left, the numbering is:
1 3 5 7 9 11 13 15
2 4 6 8 10 12 14 16
You want to test the resistance on the electrical connector side. One wire should be orange the other would be white.
This information is for a 94/95 accord. 96/97 is different and I can tell you that information if needed.
What accord are you driving?
Old May 14, 2011 | 12:12 AM
Tek310's Avatar
EX VTEC with P0A-A51
Old May 14, 2011 | 11:06 AM
  #17
Tek310's Avatar
I got it finally read 812ohm so it's normal. Guess that means my ECM is bad.
Old May 14, 2011 | 08:11 PM
  #18
Agree, looks like ECM is problem.
These are readily available through car-part.com for < $30.
96hondaaccord
Aug 11, 2006 01:36 PM
wj2
May 25, 2006 05:07 AM
wj2
Sep 16, 2005 03:10 AM
Jun 16, 2005 10:54 AM
cgarcia275
May 15, 2005 07:47 PM
