Window Motor or Switch?
Old Jul 18, 2007 | 08:27 PM
ckeeldoc2b
Default Window Motor or Switch?
98 Honda, drivers window will not roll down. All the other windows work at thier switches and on the drivers, "master control" (don't know what it's really called). It worked when I bought the car, then intermitantly quite maybe two or three times, then just started working again. This time it has been nonfunctional for 2-3 mos. Is it a switch problem or motor? It doesn't make any noises or anthying it's like it just lost power to that one switch or motor?
Old Jul 20, 2007 | 03:15 PM
deserthonda's Avatar
Default RE: Window Motor or Switch?
you need to get to the motor connector and see if there is power and ground going to the motor ,, if you do most likely a bad motor,, if not , could be a switch or wiring ..
Old Jul 21, 2007 | 08:17 AM
ckeeldoc2b
How do I check the power, and Ohms' Meter?
Old Jul 21, 2007 | 10:02 AM
sir_nasty's Avatar
Pop the door panel off or find a way to remove the switches and use a volt meter to see if you've got any power to it
nielsenjc1980
Sep 19, 2013 04:26 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
93hondaccord
Oct 13, 2011 09:24 PM
