Window out of track
Old Nov 26, 2011 | 11:55 PM
sssmjd's Avatar
Default Window out of track
Window is coming out of the track during closing. Side to side movement when beginning to close. removd door panel, cleaned and lubed window weather strip. Checked bolts for left and right track runners, all tight. Checked center track bolts, all tight. Checked two window bolts, all tight. In the middle of trying to adjust to minimize window movement by loosening bolts , fully raising window, tightening bolts. No improvement. Not convinced the problem is with the weatherstrip...dealer price is $100, found one at the local scrap yard but have not installed yet. Any suggestions?
Old Nov 27, 2011 | 05:43 AM
If window is properly mounted, the run channel must be damaged and guides the window to leave channel. Replacing run channel should fix the problem.
Extremespeed
West
Oct 21, 2012 11:59 PM
Extremespeed
West
Feb 23, 2012 02:32 AM
Extremespeed
West
Dec 13, 2011 02:03 AM
MessAround
Jun 17, 2011 07:13 PM
heardaneaglecry
Sep 28, 2009 05:17 PM
