window seal
Old Jun 11, 2006 | 09:45 PM
bigeyedphish
Default window seal
Hello all!.....my first post here
The window on the driver's door does not seal properly. I am looking for the proper name of this rubber strip so i can replace it myself. Which leads me to my next question...will this be as easy and straightforward as a project as i think it will? I am by no means a car expert, but I'm good with my hands and figuring new stuff out, so I figure I am at least capable. Any help is appreciated!
Thanks!
Old Jun 11, 2006 | 10:05 PM
deserthonda's Avatar
Default RE: window seal
first off Welcome to HAF,,,,,,,,,
secondly,, please input the year and model on your sig so all the members know what car you need help on..
the part in the pic is called the window run channel........looking at the pics, you might want to try to reposition it on the outer side of the window and leave it like that for a few days , since it is rubber , it might remold itself properly without the need of replacing it.........just get a small screwdriver and gently pry out on it as windlw goes up , so run channel will be on the outside of the glass..
if you ned to replace it, you need to remove the door panel. disattach the glass for the window regulator, 2 10mm bolts, lower regul;ator all the way down, . lay the glass gently down in the door cavity and replace the run channel.
make sure that run channel goes properly into the track guides.
Old Jun 11, 2006 | 10:21 PM
bigeyedphish
Thanks!
I have a '96 accord, V6, 4 door
I have guided the window back under the seal as you suggested, and it always manages to find push back out of the channel like it is now....maybe i should apply some heat to try to reshape it again. BUT...looks like I'll be going for the replacement. Thanks for the help and warm welcome!
Old Jun 11, 2006 | 10:32 PM
... trying the heat gun might be a good idea,, do not overheat it or it might deform the channel , leave it alone for a while afterwards hopefully it will mold itself back to original position...if not you are correct ,time to replace it ..
And thanks for inputting year and model on the sig
Old Aug 22, 2010 | 06:43 PM
searey's Avatar
Default window run channel '01 accord ex
I also have a question about the run channel. Mine for some reason has started to "fold out" on the drivers side and is grabbing the window creating a very slow window action when the button is pushed. any suggestions? thanks in advance
Old Jun 24, 2014 | 05:46 PM
jkowtko's Avatar
Almost A Senior Member
Bump.
Our '96 Accord 4dr has the same issue as the OP ... run channel gets folded under in the right rear corner (out several inches from the corner on each side). Using a credit card we can carefully raise the window and get the glass under the channel lip, but this is a short-term fix as the next time you open the window the rubber will curl back int.
Question -- has anyone fixed this relatively well by bending the channel rubber out and/or heating it? Before i drop $75 for a new run channel I'd like to see if there are any quick fixes that seem to be working.
Or ... is the problem in the window glass? Gradually losing curvature over time? I had seen suggestions that window curvature changes were responsible for many of the "slow power window" operation problems.
Thanks. John
2010HondaAccordLiquidMetal
Jan 21, 2018 10:06 PM
jrobida
May 16, 2015 08:18 PM
Michael Bomes
Sep 9, 2012 03:12 PM
mmazb3
Nov 26, 2007 03:16 PM
