Window switch help and Serpentine
Old Apr 25, 2020 | 11:32 PM
Seanjordan20's Avatar
Measure the diameter of both pulleys and post it. The original should be 2" or just above. If your new one is within 1" then you should be able to produce enough power. You are working with a 350 alternator and 250 should be more than enough.
Old Apr 26, 2020 | 12:10 PM
Have you checked the crankshaft pulley? There's a layer of hard rubber between the hub and the outer parts with the belt grooves. Sometimes that hardens or gets oily and can slip. Then the crankshaft pulley isn't properly driving the belts.
dennyimr
Nov 13, 2020 12:26 AM
TwistedC
Mar 9, 2019 12:46 PM
95hndaacrd
Jun 8, 2012 04:37 PM
crvone
Jun 13, 2011 11:45 AM
jic
Jul 14, 2007 10:57 PM
