right window switch on main control
Old Jul 25, 2018 | 06:23 PM
dennyimr's Avatar
Default right window switch on main control
Hi, I have a 2015 accord sedan ex- l, 4 cyl, auto trans, 38K miles, kept it after lease ended. Today, the right window switch on the drivers side door main control stopped working. Neither up, nor down. Everything else works fine. The right door window switch works fine also.
Any troubleshooting suggestions will be greatly appreciated.
Thanks, dennyimr
Old Jul 26, 2018 | 02:48 PM
The Toecutter's Avatar
Is it possible you turned off the "master" switch, that basically disables the window switches?
Old Jul 26, 2018 | 04:16 PM
Seanjordan20's Avatar
Could be water damage. That switch might be bad if everything else is working as it should
Old Jul 26, 2018 | 09:22 PM
Thanks, dennyimr
Try resetting the power window switch. At the driver's master switch, lower the right window and hold for 3 seconds; then raise the window and hold for 3 seconds. If that doesn't fix it, then do the same procedure at the right window switch.
Old Nov 13, 2020 | 12:17 AM
jdlarsen's Avatar
redbull-1, sorry to revive an old thread, but I joined this forum because of this post. I was just about to drop $140 on a replacement master door switch and this one short answer buried at the bottom of my last search result fixed the issue. My front passenger switch on the drivers side master was not working when all other switches worked...even the passenger switch on the front passenger door worked, so I knew the motor was fine. When I came across this thread, I did exactly as you said in your reply and holy crap, it worked!!
Thank you so much for saving me the hassle and cost!
Old Nov 13, 2020 | 12:26 AM
You're welcome. The info. is actually part of Honda service instructions.
Steve Remich
Feb 10, 2020 02:25 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
crazylegs12
Oct 15, 2011 07:48 AM
vuthang
Jul 9, 2009 09:52 AM
