Wipers go too far !
Old May 11, 2010 | 09:33 AM
hallstevenson's Avatar
Default Wipers go too far !
I've got a '99 Accord EX 4-door. Every so often, the wipers will go too far "left" (when sitting in car) and if I'm driving on the highway, they've actually went OFF the windshield !!
Is this something that could be "adjusted" in the linkage or is it likely a motor problem ?
Old May 11, 2010 | 10:15 AM
Check whether the nut holding the wiper arm (#19) is loose. If so, you can reposition the arm & re-tighten. Probably want to remove the arm & clean out any metal shavings from the tapered hole & the knurled shaft.
Otherwise you gotta go diving below the cowling to look for loose linkages (#9, 10, etc) (they've got something like balljoints) that drive the wipers.
Old May 12, 2010 | 04:22 PM
When I looked for a replacement wiper motor (I suspect the motor is fine and it's a linkage problem), they always listed bushings as "related items". Does Honda not use bushings since they have tapered and knurled shafts ? Actually, they have *both* ? I'd think one or the other would be sufficient.
Old May 12, 2010 | 06:06 PM
deserthonda's Avatar
you should make sure that the nut is not loose before anything else..
if nut is tight, you can grab the arm and see how much movement it has ,, if very little, remove the arm and reposition it and tighten the nut..
if a lot of movement,, chk the linkages or linkage assembly # 9, 10, 8
Old May 12, 2010 | 06:21 PM
I haven't used a wrench on it yet, but using my fingers, I can't budge it. I realize that's not a good test so I will use a wrench or socket before I proceed.
Check them and what ? Are they adjustable ?
Old May 14, 2010 | 07:09 AM
The nuts appear to be properly tight. What I noticed when I pulled the cowling up was the hole in, I think, #9 or #10 (though they don't appear to have holes) appear to be opened up too big. Or, is the hole a "cam" type hole that creates the swiping motion ? I could be completely wrong though...
Old May 14, 2010 | 12:25 PM
I think the ends of #9 & #10 are supposed to have some kind of ball & socket arrangement. Sounds like maybe parts of that (plastic socket bushings?) is missing. If the plastic socket broke & fell out, then you probably have to buy the pushrod #9 or #10.
One Legged Eagle
May 10, 2014 12:37 PM
justin21x
Mar 22, 2011 01:54 PM
mww12
Feb 11, 2010 01:15 PM
NICK63
Nov 2, 2009 11:57 AM
jayhova804
May 3, 2005 09:22 AM
