Wipers, Headlights, Turn Signal problems on 96 Accord
Old Aug 28, 2013 | 01:20 AM
Bobdurfob's Avatar
Default Wipers, Headlights, Turn Signal problems on 96 Accord
Recently my Accord has been acting up. For the past week, every time I turn on the left turn signal, my wipers would start going. In the past few days, the the windshield cleaning fluid would start going off as well. Sometimes both would start going off on their own. The same happens ever once in a while when I turn on the headlights. The left turn signal also has a tendency of staying on and flickering from time to time when I turn the headlights on.
I removed the fuse for wipers to stop them from going off, but that's a stopgap until I figure out what's wrong. I've tried looking up the problem on this forum, but I can't seem to find any guide that would help.
I've never done work on cars other than basic maintenance such as oil changes, so I'm hoping I could get some help in a way I can understand.
Thanks!
Old Aug 28, 2013 | 08:31 AM
Dr. Drivability's Avatar
sounds like a faulty combination switch...i'll have to check diagrams after i get my 4th cup of coffee this morning...
Old Aug 28, 2013 | 03:22 PM
Since the combination wiper switch and the combination light switch are separate components, it may be an intermittent short at the Integrated Control Unit (ICU) or some wiring or connection leading to the ICU.
The integrated control unit is located at the under-dash fuse/relay box. The combined wiper/washer circuit (intermittent wiper On input and washer ON input) runs through the ICU. In addition, the side marker flasher relay circuit runs through the ICU.
Old Aug 28, 2013 | 08:25 PM
you're right Red, might have been the ford, or was it the GM i was working on last week???
Old Aug 29, 2013 | 12:45 PM
ActAccordingly's Avatar
I would clean up the grounds for the headlight wires, etc, and then disconnect the battery for a few minutes to reset the ECU for starters.
Old Aug 29, 2013 | 01:41 PM
What does resetting the ECU have to do with the OP's problem?
Old Aug 29, 2013 | 01:51 PM
absolutely nothing...
Old Aug 30, 2013 | 12:46 PM
Bobdurfob's Avatar
Wow thanks. I'll start looking into that now.
Old Apr 18, 2021 | 12:03 PM
Sean Maney's Avatar
Default switched headlight assembly
we replaced the headlight assembly and we right away noticed that the windshield wipers would come on with cooling fan and drivers side headlight would only working the brights. Now it seems like the wipers come on with headlights brake lights and turn signals
ransrobs
Jan 12, 2015 08:01 AM
BJO
Nov 16, 2014 04:34 PM
outlaw423
Dec 31, 2011 06:21 PM
howheather
Sep 7, 2010 07:18 PM
Mzanuel513
Nov 15, 2007 05:14 PM
