Wipers will not turn off where is relay?
Old Jan 10, 2009 | 12:17 PM
dsldsl1980
Default Wipers will not turn off where is relay?
I was putting a remote start in a 2008 Honda Accord and during the process of testing wires I think I blew the relay or wiper motor. The wipers will not turn off unless I take the key out of the ignition when they are at rest. Do you think it might be a relay, and if so where is the wiper relay?
What I have found
1. The wipers will not turn off unless key removed in down position
2. When in off position the wipers move in fast mode
3. Intermitant wipers do not work, they work in slow mode
I have disconnected everything from the remote start so I know it is not a residual problem from a wire I hooked up. Thoughts???
Thanks!
Old Jan 10, 2009 | 08:24 PM
Default RE: Wipers will not turn off where is relay?
What year/model of accord do you have? You should put it in your signature, so it will be there on every post.
Bobdurfob
Apr 18, 2021 12:03 PM
Gangsta101
Feb 10, 2013 01:50 AM
outlaw423
Dec 31, 2011 06:21 PM
howheather
Sep 7, 2010 07:18 PM
maro
Mar 9, 2008 01:25 AM
