Wrench indicator light questions
Old Oct 22, 2008 | 05:47 PM
ph3iron's Avatar
Default Wrench indicator light questions
My wife loves her 2007 Accord and took it to our long term mechanic for the 30000 miles service.
Now the wrench/service light comes on and it has "10%" left before the oil change, even though the oil looks as clean as a whistle
Is the dealer service necessary to get rid of this light?
Thanks - p
Old Oct 23, 2008 | 06:56 AM
Default RE: Wrench indicator light questions
If the oil was just changed, that probably means they didnt clear the maintenance minder. It doesnt actually measure the oil, it just keeps track of engine use. Stuff like # of starts, # of COLD starts, hours, etc. It probably even keeps track ofhow much you romp on the gas pedal.
When itshows the oil %, press & hold the select/reset button until it flashes. Release the button; press & hold it again until it changes to 100%.
Then you should remember to do you next service a bit early since that thing wasnt reset during the 30k service.
Old Oct 25, 2008 | 07:03 PM
ph3iron's Avatar
Many thanks - I assume "clearing the maintainance minder" means holding it down as you suggested?
Wife is due back in town tomorrow so I'll do it then - thanks again - p
Old Oct 26, 2008 | 01:07 AM
I would look at the owner's manual to reset the maintenance light. That should take care of the problem.
Old Oct 27, 2008 | 06:59 AM
Yup. Holding down the button is how to clear/reset the maintenance minder. That should be the owners manual too.
Tony1M
Nov 10, 2023 03:57 PM
Accord Owner
Oct 24, 2013 07:54 AM
00AccordLX5spd
May 23, 2007 01:29 PM
ArcticHonda
Feb 10, 2007 06:10 PM
EGreene
Nov 15, 2006 02:13 AM
