Yet another transmission question
Old Jan 11, 2014 | 10:24 PM
Mark Huber's Avatar
So solenoid A... It it responsible for both codes or does it have a dastardly friend... Where is solenoid A (next to solenoid B? Cos I know where that sucka is) and what are the chances that replacing this part will end my woes...
Old Jan 11, 2014 | 10:25 PM
Mark Huber's Avatar
DTC P0747: A/T Clutch Pressure Control Solenoid Valve A Stuck ON
DTC P0752: Shift Solenoid Valve A Stuck ON
They are different solenoid valves.
Excellent... And their location?
Old Jan 11, 2014 | 10:31 PM
See attached.
Generally with these codes, the techs would first drain the ATF through a strainer to check for metal debris or excessive clutch material.
Attached Thumbnails Yet another transmission question-component-locations.jpg
Old Jan 11, 2014 | 10:32 PM
Mark Huber's Avatar
Ok.. I know where the a/t clutch pressure control solenoid is... It's just below the mass air control is... It's a tandem double solenoid plate A, B..
shift solenoid A I'm not sure of yet.. My guess its next to shift solenoid B?
Old Jan 11, 2014 | 10:37 PM
Mark Huber's Avatar
OOOOO I C... Sweet... Um.. I can see how they are represented dimensionally in the diagram but is solenoid A and C located radiator side or firewall side?
Old Jan 11, 2014 | 10:47 PM
It's near the front of the car, radiator side. Shift Control Solenoid Valve A has a 2P Black connector; whereas, Shift Control Solenoid Valve C has a 2P Brown connector.
Old Jan 11, 2014 | 11:12 PM
  #17
Mark Huber's Avatar
Ok... Thanks... I know I can get shift solenoid A for around 60 bucks... But apparently the tandem a/t clutch pressure control solonoids A and B are (dropped jaw) DAMN 400 bucks at autozone... Suggestions on a site that won't force me and my kids to eat ramen for a month to buy the parts?
Old Jan 11, 2014 | 11:33 PM
  #18
Mark Huber's Avatar
Hoi red bull-1 thanks for the assistance... If this puts my accord back on the road.. You just made my 2014 all time best moment list...
Old Jan 13, 2014 | 08:02 AM
  #19
OK, sorry for confusion; that's what I get for skimming the first couple postings. I feel pretty silly for not seeing that in the first post...
nafango2
Nov 29, 2007 10:02 AM
HundaAccode
Jun 9, 2007 09:11 PM
camusmuse
Dec 30, 2006 05:10 PM
Irish Kevin
Mar 18, 2006 09:41 PM
Tonyride
Mar 1, 2005 09:23 AM
