HAF Help & Suggestion Center Need help with HAF? Ask. Have a suggestion to better HAF? Tell us here.
89 LXI HELP
Old Nov 8, 2006 | 03:51 PM
simply6foot2
Default 89 LXI HELP
Hey guys,
I have this little car and I am intrested in doing a little "work" to it. With a $200.00 price tag there isnt much to complain about
other than having to replace a motor mount and the fuel pump. My question is how hard is it to replace the bottom rear motor mount, and how can I re attach the Speedo cable? Any illistrations or descriptions are much appreciated. Thank you.
S62
Old Nov 8, 2006 | 04:12 PM
sir_nasty's Avatar
Default RE: 89 LXI HELP
the motor mounts aren't to hard (see the attached photos) just support the engine with a jack while you're doing it and that will make your life easier, also, the speedo cable when you say re-attach it what is wrong with it? Speedo not working? How do you know it's disconnected and not broken?
[IMG]local://upfiles/3079/BBA432FBDF5847AEAB1F0D8736CA715D.jpg[/IMG]
[IMG]local://upfiles/3079/76E47FC4078D48EA9EDB65B490930A17.jpg[/IMG]
Old Nov 14, 2006 | 09:41 AM
simply6foot2
Thanks for the help! I really appreciate that diagram
As for the speedo cable, I know its not attacked. I have been checking the hoses and I found the cable attached to the speedo and it runs down through the engine bay but it was just hanging. It has a slight bend to it but it dosnt look broken. I have a good Idea that it may work but I didnt know if someone had a little more input. I also know that you must hook it into the trannie (im pretty sure)
- Thanks
S62
mkirby626
Jun 15, 2015 07:48 AM
mamtsberg
Mar 17, 2010 09:15 PM
phil
Apr 5, 2009 07:15 AM
TheDarkRacer
Sep 3, 2007 09:59 PM
fleabag711
Apr 9, 2006 06:07 AM
