2.5" Piping problem
Old Sep 20, 2010 | 08:55 PM
HondaMizzan's Avatar
Default 2.5" Piping problem
Hopefully get some help here. Gator was a great help to me awhile ago when I first came here about swapping out for this better exhaust.
Well, here is my problem, I'm getting a lot of vibration from the piping hitting the heat shield around the S turn in the exhaust as well as the piping hitting the lower A-Arm mount where it goes underneath the lower A-Arm for the rear Passenger's side wheel. I'm not quite sure what to do here. I thought perhaps of putting some high-heat rubber between the piping and heat shield and perhaps to put some around the A-Arm mount as well.
Any help is greatly appreciated.
Old Sep 20, 2010 | 10:09 PM
I think you'll do better by loosening the pipes from each other, adjusting the hangers, & supporting the pipes. Twist them into the best position before re-tightening the pipes. It can be a PITA trying to hold everything straight & level. Try stacking boxes or blocks of wood to hold everything.
It could be that the pipes hitting HERE is really caused by a stretched-out hanger over THERE. You have to kinda look at the entire system and how the hangers work together.
1999HondaAccordEXV6coupe
May 19, 2013 06:59 PM
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
