AEM V2 Install on 03 Coupe
Old Dec 31, 2007 | 12:51 AM
apg96's Avatar
Default AEM V2 Install on 03 Coupe
How hard is this install? I have basic abilities to install parts. Pretty much I can do short shifters, sway bars, but I saw that the V2 requires you to remove the bumper and drain your coolant and Im a lil worried about having to do that. I want to have it installed by Sunday b/c Im taking the car to the track.
Old Jan 1, 2008 | 10:39 PM
AxCxCxOxRxD's Avatar
Default RE: AEM V2 Install on 03 Coupe
I just installed the Fujita CAI this morning. Taking off the bumper isn't really a problem. all u do is take all the visible clips and screws off and gently pull one side off at a time. It is highly recommended u have someone help u bc when u pull the bumper off the first time it will surprise u. also bc u wouldn't want it to fall and get scratched up. It will also make ur installation a lot easier with the bumper off. as for the coolant, u got me there.
Old Jan 2, 2008 | 12:43 PM
falkore24's Avatar
I've heard that most people don't do the coolant thing .... it is so that when you pull the TB cooling lines and bypass it, so you don't spill a few drops on the ground. As mentioned, the bumper is no big deal either. If you can do a swaybar, then you can do an intake.
Old Jan 2, 2008 | 01:57 PM
vwl1980's Avatar
Bumper is very easy like they said. its just a couple plastic screws. The coolant thing i wouldnt worry about it. I have a 04 coupe. I installed my v2 and didnt do it.
Old Jan 4, 2008 | 07:27 AM
Yorty's Avatar
I also have the v2 for my 2005 coupe. You do not need to drain, and I dident even take my hole bumper off even tho it is easy. You should reset your settings or unplug the battery like they said or just wait a week because it will automatic reset it. It was the best 300 I spent it is an amazing jet sound with I think adleast 10 hp more and greattourk.
408Davis99Accord
Dec 29, 2009 03:32 PM
Urbski
Mar 1, 2008 06:06 PM
Whitefoxx
Nov 21, 2007 10:40 PM
noboundaries6289
Jun 1, 2007 02:34 PM
RTexasF
Jun 2, 2005 05:30 PM
