Cat Rattle?
Old Mar 15, 2007 | 01:08 AM
MAxElement
Default Cat Rattle?
Hi All,
I just bought a 99 ex 2.3 5spd about a month ago and all way fine untill the other day. I was driving home and heard a rattle from under the car( it only happend when i was slowing down to stop or at idle). I tried looking around , checking things out, but couldnt find the culprit. Sounded like an exhaust rattle, but after wiggling this and that, no luck. So i took it to my local guy and up on the lift we found it was coming from the catalytic conv. When we bang on it it stops for a second. He said it needs to be replaced, anyone else ever had such a problem? How long do i have before i need to replace it? Im gonna change it, i just dont want to do more damage before i can order one.... Thanks in advance for any help.
Old Mar 15, 2007 | 02:10 AM
dnask8ter's Avatar
Default RE: Cat Rattle?
one thing you might wanna do is double check to make 100% sure that the rattle is coming from the cat and not the resonator. i have a 94 ex 5spd, and something is loose in the resonator causing a very irratating rattle at a certian rpm range. (usually about 1500 to 2100)
if it is indeed the cat, i'm not quite sure how to help you. i dont have a whole lot of experience in that area.
Old Mar 16, 2007 | 04:52 AM
otsb708's Avatar
Almost A Senior Member
Back when I had my S10 I had to replace my Cat on that and it sounds like you have the same problem.
grim_reaper
Feb 22, 2012 08:59 AM
JeffB
Jan 5, 2009 03:06 PM
pyaarawala
Jun 1, 2007 01:19 PM
00calicoupemd
May 7, 2006 01:01 PM
sir_nasty
Mar 10, 2006 04:25 PM
