Header for 93 accord?
Old Feb 17, 2010 | 12:21 PM
  #21
fortyfootelf's Avatar
now im asking, if i were to skip the header swap, and go with a throttle body spacer and a performance throttle body, and replace the exaust... what exaust would you reccomend. im going to have to replace it anyway considering i rounded off the bolts trying to get to the oil pan (due to leak). should i stay with stock or add a performance one?
Old Feb 20, 2010 | 08:11 PM
  #22
g22cd5's Avatar
Supper Moderator
If you have a f22a4 engine you should take the money for the TB and the spacer and buy a used h22 top half of the intake mani and bolt it to the a4 runners. It's a bigger intake mani all around. That will give you a better gain then a bigger TB and spacer.
As for the exhaust run a 2.25' MANDREL bent or a 2 1/2' CRUSH bent.
Old Feb 22, 2010 | 09:15 AM
  #23
ok thanks for the help, bro. do you have any further suggestions? as of now im open to any, considering i have little knowledge on this vehicle. and on that pipe, is that bent enough to where it isnt too loud? im wanting to make it a sleeper. i know that i can add a silencer on it too, to make it quieter, but os there anything else?
Old Feb 22, 2010 | 09:36 AM
  #24
by the way, what does the crush bent sound like? that would give it more restriction so would it make more noise less of a low rumble that the mandrel would give you correct?
Old Feb 22, 2010 | 01:27 PM
  #25
g22cd5's Avatar
Supper Moderator
Mandrel will give you a smoother sound and flow b/c there isn’t as much turbulence as the crush bent. But if you want to be a sleeper get a RSX type S muffler they TEND to be more quite then after market.
Old Feb 22, 2010 | 02:14 PM
  #26
ok, if i were to do that would it fit outta the box? or would i have to custom fit it in order for it to fit onto my headers, and add mounting brackets too? since it is for an acura and all. i know that they are practically the "same" car different company and what-not, but is there any difference in the parts and location of how they are attached to the car? i found a whole exaust for less than 2 bills thats why i ask... otherwise if i straight pipe it would a silencer do any justice to the noise or would it leave it rumbling like a dull thunder
Old Feb 22, 2010 | 03:54 PM
  #27
RSX is more closely related to a Civic, so I wouldn't expect it to fit "out of the box".
Old Feb 22, 2010 | 04:09 PM
  #28
ok cool but a few minor adjustments and it will go on though, correct? if not then ill just finda another aftermarket one considering i dont have the necessary tools to do a major reconstruction. i dont have a welder but i do have some access to one.
Old Feb 22, 2010 | 05:03 PM
  #29
g22cd5's Avatar
Supper Moderator
I mean the RSX type S MUFFLER...not the whole exhaust and No I don’t see a rsx full exhaust working on any accord.
zacritz929
Apr 13, 2011 07:01 AM
DA KID RYU
Feb 17, 2008 10:52 PM
WRLEO
Nov 18, 2006 01:15 PM
digitalmewmew
Oct 19, 2005 08:52 PM
jmad93
Sep 15, 2005 11:34 PM
